Trolley Buses of Rockdale Kogarah & Sandringham
- Thank you
- Leopard_071
Found these old photos sranned from Kodak Slides. Hope you enyoy them. I would like help with the areas as I only know that the Depot was in Rocky Point Rd.,Kogarah. There is a Motel on the site these days.
- Attachments
- No 22 in Rocky Point Road heading for Rockdale. Any suggestions on the bus in the background ?.
- Trolly bus 1.jpg (137.2 KiB) Viewed 4135 times
- No 8 at San Souci Terminus.
- Trolly bus 2.jpg (105.23 KiB) Viewed 4135 times
- No 19 I think it is leaving Kogarah Station.
- Trolly bus 3.jpg (142.69 KiB) Viewed 4135 times
- No 16 & ? at Kogarah Station. {I Think }
- Trolly bus 4.jpg (122.41 KiB) Viewed 4135 times
- Can some help, did the buses drive through the Depot from a rear entrance, which seem to be the case here.
- Trolly bus 5.jpg (122.05 KiB) Viewed 4135 times
- Trolley Bus ? I think it is at Sandingham, am open for help.
- Trolly bus 6.jpg (92.52 KiB) Viewed 4135 times
- Trolley Bus no 19.
- Trolly bus 9.jpg (219.2 KiB) Viewed 4135 times
- Bays 1 & 4 of the Depot with No 8 in bay 1.The bus in bay 4 looks like it has had better days.
- Trolly bus 7.jpg (146.79 KiB) Viewed 4135 times
- The 4 bay Depot.
- Trolly bus 8.jpg (81.22 KiB) Viewed 4135 times
- The Depot Rocky Point Rd., Kogarah
- Trolly bus 10.jpg (187.97 KiB) Viewed 4135 times
- wyth
- Favourite Vehicle: Plaxton bodied Dennis Darts
Re: Trolley Buses of Rockdale Kogarah & Sandringham
They are beautiful pix, never knew you had trolleys there, we had trolleys back home, Bournemouth, ours looked very modern!!!! What yrs roughly were they taken?
- Dave Wilson
Photos are from the 1950s - the system closed in August 1959. AEC 664Ts and Leyland TTB4s. I think Bournemouth had 3 axle Sunbeams from the same era.
trolleybuses drove through the rear of the depot.
- vernbale
- Favourite Vehicle: N113 Orana,TRAINS,HELICOPTERS
Great old shots, we had BUT trolley buses in the 50's and 60's but not double deckers
TRAINS - LOVE the POWER and SOUND
- Skindog the Hawk
- Location: North of the airport, south of the highway...
This may be a bit of a stupid question, but aside from the not needing to lay track, was there any benefit to trolleybuses over trams?
SD.
SD.
- Bedford-29
Bounremouth last trolleybuses to be built were front and rear entrance two axle Sunbeam MF2B with Weymann H35/28RD bodywork these were only 7 years old when Bournemouth trolleybus system closed in 1969.Looking at pictures 8 & 9 road 2 looks like one of the S/Ds is sitting inside the depot.
we had trolleybuses in brisbane but only single decker and very small
- Attachments
- Brisbane Tramway Museum.jpg (75.2 KiB) Viewed 4050 times
.. Pure Gold !!! ... Thanks for posting ...
I think lighter weight and better acceleration. Although someone will no doubt be able to cite an example to counter that. Probably cheaper to buy the trolley bus as compared to a tram.Skindog the Hawk wrote:This may be a bit of a stupid question, but aside from the not needing to lay track, was there any benefit to trolleybuses over trams?
SD.
EDIT: Actually, another advantage would be that a broken down trolley bus doesn't necessarily block other trolleybuses - it can just be detached from the wire.
- Bedford-29
A trolleybus had the advantages of a motor bus pull into a normal bus stop and depart like a normal motor bus a trolleybus may have been confined to 600 volt overhead wires but they did have battery`s for off wire movement around the depot yard and sometimes use the battery`s in case of power failures to get to the terminus or the depot.But a modern trolleybuses nowadays are fitted battery`s or a diesel engine for off wire movement.
One of the attractions to English operators was that many had considerable money tied up in power supply infrastructure built for trams, that was in reasonably good condition. The TB allowed them to withdraw the trams without wasting assets.Skindog the Hawk wrote:This may be a bit of a stupid question, but aside from the not needing to lay track, was there any benefit to trolleybuses over trams?
SD.
- Leopard_071
Found 5 more photos of Rockdale Trolly Buses.
- Attachments
- This must have been "Opening Day"
- Trolly bus 15.jpg (108.98 KiB) Viewed 3907 times
- I think that photo must have been taken on opening day as well.
- Trolly bus 13.jpg (129.3 KiB) Viewed 3907 times
- Heading along Grand Pde., towards Sandringham. With Botany Bay in the background.
- Trolly bus 14.jpg (123.91 KiB) Viewed 3907 times
- 2 buses at Kogarah Station I think.
- Trolly bus 12.jpg (82.29 KiB) Viewed 3933 times
- Trolly Bus No 5. On the back of the photo is "Trolley Bus tour at Sandringham Terminus 1953". The looks like it has had a resent overhaul by the good looking bodywork.
- Trolly bus 11.jpg (114.98 KiB) Viewed 3933 times
- Bedford-29
No:5 was rebuilt like that so it would strengthen the body.S/D 1 & 2 Wylde st D/D 3,4 and 5 Potts point these trolleybuses ended there operational days on the Kogarah.
They were rebuilt, but I don't think they saw much use at Kogarah because of the lack of rear door.
That pic would be on a AETA tour, some familiar faces there.
- dougea
- Favourite Vehicle: Sydney half cab double deckers
I think Pic 2 and pic 6 were taken at the same place, Sandringham, possibly same day, same bus.
Doug
Doug
Many of you may have a copy of "The Sydney Trolley Buses", published by Ian MacCowan back in 1988.
A much updated version of this book is now at the pre-publication stage, and may be available by the end of this year.
Just had a look through said book, and it mentions No 5 receieved an overhaul in 1953, so is probably just out of Randwick workshops at that time.
Interesting to note that although closure of the TB system had probably been planned well in advance, one vehicle was still being overhauled at Randwick at the time of the system's demise.
Remember in the mid-1950's traveling along Alison road Randwick near the RACECOURSE and looking across to the left from Rte 399 MAROUBRA BEACH top deck DDs and noticing at least 2 Trolleybuses parked in RANDWICK Tramway Workshops, near a large building in the middle of the site. I presume these were KOGARAH vehicles being overhauled.
rOjO43
- HiHo
- Favourite Vehicle: Mk iv Merc.
These are great photos and Urabus could add more but he is in Longueville private hospital with a brokern ankle and would like visitors.wyth wrote:They are beautiful pix, never knew you had trolleys there, we had trolleys back home, Bournemouth, ours looked very modern!!!! What yrs roughly were they taken?
HiHO
I note in the photos that bus 10 at the entrance of the depot has the thick black line and is in original condition at the end of its life.. .
Regard Greens...
Regard Greens...
- HiHo
All the Kogarah fleet had a thick band around the lower deck window as built. Rebuilding commenced in 1952 6 12 15 and 18 received thick bands around the windows on each deck all other vehicles rebuilt were given thin bands. 18 was also givern thin bands after a 1958 repaint.It was the only vehicle to have 3 variations in its working life. 10 was never rebuilt. This information came from URABUS.
HiHO
Thank you kindly for that interesting imformation I was too young to remember any real detail when I saw them running, I went on them on the last day in traffic in 1959 .
Regards greens...
Regards greens...
Wonderful pix. Thanks. Love the robust little poles supporting the time clocks at the terminii, complete with standard "tramway" finials !!!
And can somone put names to the guys in the tour pic please? (Arthur "Trolley Pole" Perry is an obvious stand-out.....
- Leopard_071
A few photo of single deck trolley buses in Sydney
- Attachments
- Trolley Bus No 2, the "Overhead Gang" working in the background.
- Trolly bus 17.jpg (87.08 KiB) Viewed 3514 times
- Trolley Bus No 2 on the move some where.
- Trolley bus 19.jpg (97.55 KiB) Viewed 3514 times
- Every one is having a good look at No2.
- Trolley bus 18.jpg (95.38 KiB) Viewed 3514 times
- Trolley Bus No1 {thanks "Bedford} in the City.For all I know it may not evern be Sydeny.It dose look like it is coming out of Rushcutter's Bay Depot. Hope some one can tell me more as there are heaps of tram lines.It must be 1st day of running by the crowd.
- Trolly bus 16.jpg (98.36 KiB) Viewed 3514 times
- Bedford-29
Your last picture in the S/D trolleybus line is No:1 not No:2.And by the look of No:1 it looks like its at Rushcutters bay somewhere near the depot.
