Tasmania - 01/08/2011-04/11/2011
- stevegj52
- Favourite Vehicle: Volvo Bus & Coaches
Re: Which Vehicle Is It - Tasmania
Incorrect and lower, the number you are reffering to is the file number. I will give you a clue, belongs to Northern operator who we visited on the last tour
Volvo B8R,green efficiency built in
- Tas Bus Nut
- Favourite Vehicle: Mercedes Benz O303
- stevegj52
Correct, MersyLink #15Tas Bus Nut wrote:#15
- Tas Bus Nut
You certainly made that one difficult, with NO livery/signwriting Your CLUE helped though
[/b]
[/b]
- Tas Bus Nut
Higher^^yoda wrote:72?
CORRECT Sh#t, that didn't last longstevegj52 wrote:#73
- stevegj52
Here you go Neil, this one should be easy, even has a livery
- Tas Bus Nut
#5 without looking
- stevegj52
Neil is correct, the number of the Mills Tui 18.280 is # 5
- stevegj52
Been dead here, so here is another non Metro
- Tas Bus Nut
- Tas Bus Nut
Wilbur's pride & joy. Remembered the wheel trims
- Tas Bus Nut
Let's keep this thread going - What is the # of this CB60
- Tas Bus Nut
When I checked, I had USED the above pic on quite a few occasions, SO I better make it harder with a DIFFERENT vehicle
What is the # of THIS PARTICULAR CB60.
- Tas Bus Nut
Yeh, maybe, BUT what # is the busyoda wrote:Struth, that's an old pic.
yoda wrote:323 is located at St Canice Avenue, Lower Sandy Bay.
- Tas Bus Nut
I KNOW THAT, but I just wanted you to answeryoda wrote:yoda wrote:323 is located at St Canice Avenue, Lower Sandy Bay.
What did I find this interesting label on?
- Tas Bus Nut
Most of the N113s THIS one, probably #622
I don't have that problemTas Bus Nut wrote:Most of the N113s
Higher.Tas Bus Nut wrote:THIS one, probably #622
- leyland clippers
- Favourite Vehicle: Ansair buses & coaches
