[Mar/Apr 2021] SA Transport observations
Re: [Mar/Apr 2021] SA Transport observations
Does anyone know where 2203 ended up after it's engine rebuild?
- Lt. Commander Data
Still sitting at Aldgate depot last time I passed it
Busways MAN 18.280 HOCL-NL #2718 caught fire at Bedford Park this evening
I think it’s just the engine bay and the back of the bus
- Favourite Vehicle: XPT
Next station is Victoria Square. Change here for all trains.
Based off this it looks like it went to the front too, unless im seeing it wrong? https://www.reddit.com/r/Adelaide/comme ... i/gtqug66/
A comment left on a post that was put up on Facebook by 10 news first Adelaide last night states that the bus that caught on fire might have been Busways MAN 18.280 ABM CB64A 2718 the comment says it was 2718
Scania L94UB 3270, which was retired in November last year has re-entered service tonight.
How many tourists are going to be willing to be imprisoned inside this?
https://www.theguardian.com/travel/2021 ... ilau_email
A lot. It adds a bit of life to those carriages made of dull, corrugated metal.
Is the view from the windows clear from the inside or is it like an AOA on an AdeMet bus where the view is blocked slightly?
Yes, the image posted above shows it is 2718.Campbelltown busboy wrote: ↑Thu Apr 08, 2021 1:37 pm A comment left on a post that was put up on Facebook by 10 news first Adelaide last night states that the bus that caught on fire might have been Busways MAN 18.280 ABM CB64A 2718 the comment says it was 2718
I would be asking for a refund if I found my compartment had this over it, after all isn't part of the experience seeing the view? Some years ago I stayed at a resort hotel in Queensland where the room was advertised as water view but when we got there, the palm trees in the grounds had grown higher and heavily filtered the view. The accommodation grades were obviously set years previously when the trees hadn't grown and they hadn't reviewed the gradings over the years. However, the hotel acknowledged this without dispute and willingly gave a credit for the difference. The Ghan is basically a rolling hotel......lunchbox wrote: ↑Fri Apr 09, 2021 11:11 am How many tourists are going to be willing to be imprisoned inside this?
I wonder if you might have a new ally in the fight against AOA wrap lunchbox. I'm not sure if it's allowed to cover emergency exits with wrap or, if it is, I wonder whether it should be, as surely wrap would make it more difficult to break the window out. Modern Australian buses typically only have one emergency exit either side over the front wheel arches. The traditional rear window exit has long since disappeared with the advent of engine firewalls at the back. The downside with all this was demonstrated in that terrible Brisbane fire where the fire was down the front and the front window exits or door couldn't be accessed and the emergency door release over the centre door was hidden because, naturally, smoke rises to the ceiling first, so the passengers were trapped down the back and were saved only because a passing pedestrian outside kicked in the centre door.
You'd think lessons would be taken from this, but nothing seems to have changed until the new Custom Denning Element came along with two centrally-located window exits on either side and a rear window exit at the back. I don't know if you're still with APT lunchbox, but maybe the location of emergency exits and the effect of wrap on inhibiting exit through windows is an important one to raise with authorities. The same issue of course applies to trains and trams.
- Favourite Vehicle: Anything without SCANIA badge.
1502 back at Port depot. That’s Port Adelaide not Port Pirie.
Unusual to see Port Depots 1390 running on a Saturday afternoon seen at Marion on a 300 to Arndale around 1430hrs
With nearly 90 extra buses out on Footy Express services, buses that are normally not used on weekends often get used when there is Football on at Adelaide Oval.
Major delays for Hills bus services heading out of the City tonight due to a breakdown on the SE Freeway - many services running over an hour late, some up to 2 hours late
The double decker buses , are they allowed to use Greenhill Road or Upper Sturt Road ?Lt. Commander Data wrote: ↑Mon Apr 19, 2021 8:17 pm Major delays for Hills bus services heading out of the City tonight due to a breakdown on the SE Freeway - many services running over an hour late, some up to 2 hours late
No, and 14.5m buses are not allowed to use any alternative route either. I believe staff at Aldgate try to keep artics away from both roads as well due to tight corners and little passing room
1501 is at Port Pirie now (source: Ademet group on FB)
The following buses have been transferred from Southlink Aldgate to Torrens Transit's Morphettville Depot--
Scania's 3227/3229/3231/3232 today.
Does anyone know why TT renumbered 1791 and 1792 to 5701 and 5702? Also, why did those SouthLink buses (3227, 3229, 3231 & 3232) get transferred?
Maybe some of the short wheelbase Bustechs will go to St agnes for the OBAHN hence these ex Southlink units replacing those? Im just having a guess no factual information
Wouldn’t have been TT renumbering it, would have been DIT
Presumably the Hills CB80s are to help with rail replacements
