Man SL200 injector pump oil level and type of oil
New Users (or anyone else) is/are welcome to ask questions in here to which the answers might be obvious to most but you simply don't know yourself or are unsure where to find the answer. You can also ask questions about the working of the forum or anything else you may think of.
chev4life
Post by chev4life »
Hi there. Hadn't started the bus for 8 months and got diesel to injector pump and started fine and idled well but when I revered the motor the revs would stay up untill I went to turn off on the injector pump and would come back to idle. Can't see any oil when took off bung on top of injector pump. Any ideas or help would be great.
Guy_Arab
Favourite Vehicle: M.A.N Bus & Guy Arab
Re: Man SL200 injector pump oil level and type of oil
Post by Guy_Arab »
chev4life wrote:Hi there. Hadn't started the bus for 8 months and got diesel to injector pump and started fine and idled well but when I revered the motor the revs would stay up untill I went to turn off on the injector pump and would come back to idle. Can't see any oil when took off bung on top of injector pump. Any ideas or help would be great.
Had same problem with my SL240 change filter ( make sure its not replaced with a paper one ) cleaned filter near pump
Then problem did not accure again PS I have all manuals including factory engine repair manual
Guy Arab
Return to “New Users/Ask a Simple Question”
