B59 Transmission
B59 Transmission
Hi I have a B59 bus and have changed the diff ratio from 4.8 to 4.3 it now cruises a 100kph with no problem on the flat, but really struggles on the hills. I feel it needs more gears in the gear box as it is only a 2 speed.Does anyone know what gearbox will fit as it seems a very short distance from engine to diff, and where I can get one from.Automatic or manual? Thanks.
- mrobsessed
- Favourite Vehicle: AEC Reliance
B59 Transmission
They were available with Allisons from new - and they go really hard as well!!
Re: B59 Transmission
Thanks mrobsessed but do you know what model allison transmission (assuming there is a few) And are they 3 or 4 speed and any idea where I could get one. Prefrebly in vic.Thanks.
You could try a AT545 which is a 4 speed auto, handles up to around 230hp- 240hp. They should be readily available around the place, even seen some on ebay.
http://www.ebay.com.au/itm/Allison-545- ... 19d2de4e8b
I've got one in a Isuzu powered Bedford, it goes well.
thanks mate bought that transmission on the weekend, now time to see if it will fit. May take some time though.ax8 wrote:You could try a AT545 which is a 4 speed auto, handles up to around 230hp- 240hp. They should be readily available around the place, even seen some on ebay.
