[Jul/Aug 2018] SA Transport observations
Re: [Jul/Aug 2018] SA Transport observations
Postby paulgersche » Thu Aug 16, 2018 8:30 am
Skexis wrote:
Tim Williams wrote:Honestly, the comments you blokes make about Bustech buses are, quite frankly, puerile - if you have genuine criticisms of their products, then argue your points out, in a reasonable and well constructed manner.
Ok then, how about the air con being pre-set to 22 degrees and the driver is unable to alter it? As such we'll always be too hot in summer and too cold in winter. I see that as a major design flaw that makes the drivers job just that little bit harder than it needs to be. Over to you.
I wouldn't complain about a bus arriving at my stop on a 35 degree summer day with the internal temp set at 22 - nor would I complain in winter on a 15 degree day!
Paul
paulgersche
Has thanked: 47 times
Been thanked: 22 times
Postby tonyp » Thu Aug 16, 2018 8:47 am
Paul
Perhaps you don't have to sit in the bus all day! It should be possible to control the a/c from inside the bus. Perhaps it was deleted as an option in the specification?
Has thanked: 1088 times
Been thanked: 1173 times
Postby Daniel » Thu Aug 16, 2018 3:12 pm
busrider wrote:As in the windows are lower, or the seats/floor are higher?
The window line rises up more gradually and the floor is lower so there is no step for the centre door. There is a gradual slope though to ensure the internal steps up to the rear are not excessive.
Daniel
Has thanked: 364 times
Been thanked: 967 times
Postby Daniel » Thu Aug 16, 2018 3:14 pm
tonyp wrote:
Paul
The automatic temperature control is to stop drivers from setting stupid temperatures which annoy customers and put unnecessary wear and tear on equipment.
Daniel
Postby busrider » Thu Aug 16, 2018 6:14 pm
For those who may be interested in minor details, 1904 (Tindo) now has an orange LED desto, a replacement for the green flipdot desto it had previously.
busrider
Has thanked: 48 times
Been thanked: 234 times
Favourite Vehicle: Maybe not my car...
Postby Skexis » Thu Aug 16, 2018 10:43 pm
Daniel wrote:The automatic temperature control is to stop drivers from setting stupid temperatures which annoy customers and put unnecessary wear and tear on equipment.
The passenger area of a bus in summer with the air con on full and on it's lowest setting is considerably cooler that the drivers area. The driver has to sit in that bus all day. Should passenger comfort for a few stops outweigh driver comfort for a whole day? Have you ever driven a bus or are you just a deskbound keyboard warrior? If it's the former you should know better. If it's the latter then maybe try driving a bus for a year so you can experience the whole range of temperatures in the drivers seat and then come back and we'll see if you have changed your tune. Bus drivers have a crap enough job without being forced to be too hot or too cold all day.
Skexis
Has thanked: 7 times
Been thanked: 93 times
Postby Daniel » Fri Aug 17, 2018 12:27 pm
Driven plenty of buses mate, thanks for asking. The auto button has nothing to do with crap airflow around the drivers cab - that is just poor design or lack of booster fan.
Daniel
Postby 2MSJ » Fri Aug 17, 2018 2:27 pm
busrider wrote:For those who may be interested in minor details, 1904 (Tindo) now has an orange LED desto, a replacement for the green flipdot desto it had previously.
That was fitted a couple of months ago
Cadet Coach Captain
"Who the **** is Windy?"
2MSJ
Has thanked: 144 times
Been thanked: 248 times
Favourite Vehicle: Mercedes Benz O500
Postby TT » Fri Aug 17, 2018 7:35 pm
BusTech 1906 has full temperature control for the driver to change, on a rotary dial very similar to a lot of cars. So not sure about the grizzling about fixed temperatures of 22 degrees in the discussion above.
TT
Has thanked: 152 times
Been thanked: 101 times
Favourite Vehicle: Anything without SCANIA badge.
Postby busrider » Fri Aug 17, 2018 10:28 pm
Perhaps the one at Lonsdale, 2453, has different A/C controls?
busrider
Postby The Phonj » Sat Aug 18, 2018 9:09 pm
While there are benefits as Daniel has stated; there are disadvantages of having the control (besides an on/off switch) hidden away from the driver. The biggest I can think of relates to the air conditioners fitted to the Mercedes Benz O405's 1320-1324. These are fitted with a control with two buttons: heat and cool, pressing one deactivates the other, like the transmission selector panel. Unfortunately experience has shown that sometimes selecting heat will provide cold air and conversely, pressing cool will provide hot air. I am advised that these need to be manually switched from heat to cool mode in the airconditioning unit itself. A sudden change in the weather will either leave passengers (and the driver) sweltering or shivering and there is little that can be done about it until the bus can visit the workshops and have the AC mode switched.
Get the Firefox internet browser at: http://www.firefox.com
Watch out for ghostly bus drivers!
The Phonj
Has thanked: 9 times
Been thanked: 209 times
Favourite Vehicle: MAN SL200, PMCSA body
Postby jibb » Wed Aug 22, 2018 9:00 am
3 new Scania-Bustech buses are at Scania Wingfield. These are Scanias that were to have been built by Custom Buses.
jibb
Has thanked: 498 times
Been thanked: 216 times
Postby jibb » Wed Aug 22, 2018 6:16 pm
5 withdrawn Torrens Transit MAN SL202's have been moved from Mile End to the front of Morphettville Depot-1609,1610,1611,1612,1613.
Presumably to make way for deliveries of new Scania-Bustech buses.
jibb
Postby Eurostar » Sun Aug 26, 2018 2:39 pm
Changes to T bus services at stop 27 Main South Road
From first service on Saturday 1 September, T buses will no longer be able to service stop 27 Main South Road from the city as they will move into the entrance lane to the expressway prior to the stop. This change will be in place for 12 months until further notice.
Passengers will need to board and alight T buses from the previous T bus stop at stop 24A South Road from the city. Alternatively passengers can catch F buses from Stop 27 and transfer onto T bus services at Stop 40 Panalatinga Road.
Signage will be erected at the following locations advising of the changes;
Next station is Victoria Square. Change here for all trains.
Eurostar
Has thanked: 14 times
Been thanked: 24 times
Favourite Vehicle: XPT
Postby jibb » Thu Aug 30, 2018 2:54 pm
Tram services this afternoon are terminating at stop 12 Morphett Road due to a fallen tree onto overhead power lines at Glengowrie. Morphettville are providing substitute Artis between here and Moseley Square.
jibb
Postby Eagle Eye » Thu Aug 30, 2018 6:17 pm
Buses 960, 1524 & R805 were used doing several laps. A gas bus joined the parade later (776 I think) but the line reopened shortly after.
$2,500 fines for vehicles illegally using red Bus Only lanes - could cut the state's debt real quickly if they extended that to regular Bus Lanes!
Eagle Eye
Has thanked: 118 times
Been thanked: 148 times
Favourite Vehicle: High-floor bus
Postby Former driver37 » Thu Aug 30, 2018 11:02 pm
Went past scania today and noticed a metro Tasmania cb80 artic sitting there does anyone have any idea why it's here bit far to come for warranty work?
Former driver37
Been thanked: 5 times
Postby jibb » Fri Aug 31, 2018 5:04 pm
Torrens Transit's Mile End Depot are providing Artics for the 21W Royal Sow services. In the past Light-City Buses provided Artics from Morphettville Depot.
jibb
Return to Discussion - Adelaide / SA
