Statistical Analysis of Bus OnTime Data:Route 370 case study
Re: Statistical Analysis of Bus OnTime Data:Route 370 case s
Postby BroadGauge » Sun Jan 28, 2018 10:44 pm
Much of the data seems a bit dubious. I find it hard to believe that so many routes are apparently as tardy as that site claims them to be. For example, looking at some outer suburban services that personally I wouldn't have thought would cop many delays:
Bus route 677
Richmond to Penrith via Londonderry
Sydney Buses Network
Last two weeks:
2018-01-15 - 23.1% of trips were on-time
2018-01-16 - 15.4% of trips were on-time
2018-01-17 - 30.8% of trips were on-time
Bus route 32
Warragamba to Camden via Werombi & Theresa Park
Last two weeks:
2018-01-15 - 14.3% of trips were on-time
2018-01-16 - 28.6% of trips were on-time
2018-01-17 - 35.7% of trips were on-time
Bus route 596
Hornsby to Hornsby Heights (Loop Service)
Last two weeks:
2018-01-14 - 63.6% of trips were on-time
2018-01-15 - 30.6% of trips were on-time
2018-01-16 - 30.6% of trips were on-time
2018-01-17 - 26.5% of trips were on-time
I was actually in Hornsby Heights earlier this month, and all of the buses that I saw in the PM peak were pretty much on time to the minute! :twisted:
BroadGauge
Has thanked: 188 times
Been thanked: 211 times
Favourite Vehicle: Car
Postby neilrex » Mon Jan 29, 2018 7:18 pm
Yes, I thought that was unconvincing, too.
Those timetables would already have so much padding in them.
neilrex
Has thanked: 172 times
Been thanked: 35 times
Postby neilrex » Mon Jan 29, 2018 7:23 pm
moa999 wrote:And frequency is the key part.
It doesn't matter if every 55 or 370 is running 20min late - to the pax it doesn't matter.
It's when one in 20min late, the next 10min late and the final one on time so clumping in 3s, that the passenger is upset
Sure, if the bus is 15 minutes late, then you might be catching the one which was supposed to come 15 minutes ago.
It's when there is no bus for 45 minutes, that you have a problem. This seems to be a common occurence on the 400.
Part of the problem is, a lot of the routes are so long. I am in favour of the long cross-town routes, but you need to realise that this is one of the issues that makes it worse.
The alternative would be simpler routes, needing more changes. Opal more or less has fixed the fare penalty for that. But the bus arrangements in downtown Sydney are militantly unfavourable for bus interchanges, compared to most other cities I have visited.
neilrex
Postby rpy » Fri Feb 02, 2018 9:18 pm
This seems to be a measurement of the quality of arrival forecasting in PTIPS more than a reflection on bus on time running - the number of loop services measured running almost exactly an hour late is a huge red flag.
rpy
Postby andy_centralcoast » Sat Feb 03, 2018 10:41 am
Are you saying the real time data isn't very accurate for buses?
It seems pretty good for trains.
andy_centralcoast
Has thanked: 48 times
Been thanked: 104 times
Postby simonl » Sat Feb 03, 2018 1:33 pm
Linto63 wrote:It's the old 'why do buses always come in 3?' problem. The reasons are fairly well documented and short of slamming doors in peoples faces, skipping stops or building in lots of dwell time, there is little that can be done to avoid without significantly increasing costs.
Sure there are. All door boarding, only stopping every 800m rather than every 300m, all pre paid, and priority measures will all reduce travel time variability which will make it more reliable. Then there's the aspect largely within the STA's power which is actually starting the trip on time - not practised by STA as their own data attests.
Has thanked: 849 times
Been thanked: 364 times
Postby Frosty » Sat Feb 03, 2018 6:06 pm
I noticed a 370 this afternoon left Marketplace 2 mins late by the time it got Coogee it was 30 mins late. Looking at it it lost quite a few mins along Glebe Pt Rd. Then 9 mins from King St to Sydney Park Rd. 6 mins from Sydney Park Rd onto Euston Rd probably due to roundabout works.
Has thanked: 22 times
Been thanked: 115 times
Postby GazzaOak » Sun Feb 04, 2018 6:38 am
Well, what do u expect from the 370 route where 90% of the route has traffic
White ribbon day is most sexist thing ever
GazzaOak
Has thanked: 17 times
Been thanked: 50 times
Users browsing this forum: andiye, Google Adsense [Bot] and 8 guests
