2017 Train & Bus timetable changes
Re: 2017 Train & Bus timetable changes
Postby TSE_SecretAni » Mon Dec 11, 2017 11:17 am
Is the T9 Northern Line (New Line) will be red? Or still the same yellow line like T1 Northern Line from Epping to City via Strathfield
TSE_SecretAni
Been thanked: 4 times
Favourite Vehicle: Volvo B7RLE
Postby swtt » Mon Dec 11, 2017 11:35 am
TSE_SecretAni wrote:Is the T9 Northern Line (New Line) will be red? Or still the same yellow line like T1 Northern Line from Epping to City via Strathfield
Where did you read about a T9 Northern Line?
Has thanked: 836 times
Been thanked: 366 times
Postby lunchbox » Mon Dec 11, 2017 2:13 pm
I phoned 131500, twice, requesting a printed bus timetable. Weeks later I got a single slip of paper in the post headed "Plan your trip with State Transit", describing how to get info on the internet - no explanation, no apology.
I needed a paper timetable; that's why I went to the trouble of asking for one.
131500 is hopeless.
lunchbox
Has thanked: 261 times
Been thanked: 132 times
Postby Fleet Lists » Mon Dec 11, 2017 3:48 pm
That is NOT a 131500 problem. It depends for which operator you were requesting a timetable. State Transit, Hillsbus and Internet are no longer proving printed timetable - so if you want one, you can print one off yourself from the Transport Info timetables even though they may be of a different standard to what we are used to. That is the way we are heading. Other operators will go the same way as they will no longer receive compensation for printing timetables.
Has thanked: 1007 times
Been thanked: 1107 times
Postby Tonymercury » Tue Dec 12, 2017 6:00 am
Fleet Lists wrote:That is the way we are heading. Other operators will go the same way as they will no longer receive compensation for printing timetables.
As the information stream drops to the LCD and the 'Our Glad' promises turn out to be as insubstantial as everything else.
Has thanked: 260 times
Been thanked: 335 times
Postby lunchbox » Tue Dec 12, 2017 8:17 am
[quote="Fleet Lists"]That is NOT a 131500 problem. It depends for which operator you were requesting a timetable. State Transit, Hillsbus and Internet are no longer proving printed timetable - so if you want one, you can print one off yourself from the Transport Info timetables even though they may be of a different standard to what we are used to. That is the way we are heading. Other operators will go the same way as they will no longer receive compensation for printing timetables.[/quote]
The timetable requested was for a State Transit service.
In a letter to the Sydney Morning Herald on 25 November 2017, Tony Braxton-Smith, Deputy Secretary, Customer Services, Transport for NSW, said "We understand that some customers require printed timetables". He also claimed "500 000 printed timetables are now available". I'm about to try 131500 again, quoting him.
EDIT, 21.12.17.
I finally got my STA printed timetable, by post. Unfortunately, it was two days after the date I had chosen to travel.
lunchbox
Postby Glen » Tue Dec 12, 2017 8:25 am
Did he mean train timetables?
They can be obtained but you have to go to the office to ask. They don't seem to be on display, I presume because of low print runs.
T2 is literally half an inch thick.
Been thanked: 191 times
Postby Liamena » Tue Dec 12, 2017 2:22 pm
It would be cheaper for them to print one and mail it to you, when you call, instead of printing 500,000 of the wrong ones and then throwing them away later.
There is probably only a couple of hundred people who will ask.
Liamena
Has thanked: 163 times
Been thanked: 30 times
Postby Glen » Tue Dec 12, 2017 4:01 pm
Busways offer posted timetables here:
https://www.busways.com.au/travelling-w ... -timetable
I don't know if it is a web print or a traditional timetable layout.
Postby boronia » Tue Dec 12, 2017 4:47 pm
Mr Twig wrote:
boronia wrote:That might be considered too hard for westies to understand?
You’re probably right. :)
I think Westmead was the same problem. 8V too long for the platforms.
The Westmead stoppers were off peak, so normally only 4V. Anyway, regualr BMT passengers would be used to short platforms
On again June 2019
Been thanked: 1648 times
Postby andy_centralcoast » Tue Dec 12, 2017 7:55 pm
Sydney Trains boss says no turning back on new rail timetable
http://www.smh.com.au/nsw/sydney-trains ... 02z6y.html
Interestingly the article says minor changes will be made to the Airport Line timetable within the next few weeks.
andy_centralcoast
Has thanked: 48 times
Been thanked: 104 times
Postby Frosty » Tue Dec 12, 2017 8:14 pm
What would that be Padstow & Riverwood being added back to the limited stops train or trains running non-stop through Green Sq & Mascot Stations. It would be interesting to see what is done, since dwell times are challenging at Green Square and Mascot though I've seen some measures to deal with that by removing benches on the citybound platform at Green Square.
Has thanked: 22 times
Been thanked: 114 times
Postby Stu » Tue Dec 12, 2017 9:56 pm
T8 timetable modification if most probably due to the poor connection time between limited stops services and all stops services. I would suspect that another singular station will be added to the limited stops services between the City and Macarthur to aid better connections beteeen services. It is sheer arrogance to allow the all stations service to depart Revesby 3 minutes before the city bound service from Macrthur arrives into Revesby and then expect customers to happily wait 12 minutes for the next all stations service to depart Revesby. The weekend provides 0 minutes of connection time, although there is a 30-60 second window of opportunity it will only be successful if both trains are on the same island platform (1 & 2), good luck trying to whip quickly up one stair case and down another stair case if the all stations services is on the other platform island (3 & 4) - depends on how fit you are and what carriage that you on in the Macarthur train as toubalight from it.
The positive note is the that the station staff are displaying exemplary behaviour and professionalism by being highly visible to customers all day, answering questions, assisting people in accessing the correct from the correct platform plus frequent audio announcements across the platforms.
Has thanked: 125 times
Been thanked: 462 times
Postby Liamena » Wed Dec 13, 2017 4:10 am
It seems to me that Kingsgrove would be a better place for the limited stops trains to stop. There are buses there ?
Liamena
Postby Tonymercury » Wed Dec 13, 2017 5:58 am
Frosty wrote: It would be interesting to see what is done, since dwell times are challenging at Green Square and Mascot though I've seen some measures to deal with that by removing benches on the citybound platform at Green Square.
The manager of airport link told an ARHS visit some years ago, before the gate fee removal at the two stations, that the cheap construction method means a rebuild will be needed as patronage grows.
Postby Fleet Lists » Wed Dec 13, 2017 6:49 am
Liamena wrote:It seems to me that Kingsgrove would be a better place for the limited stops trains to stop. There are buses there ?
Better than where? Not many bus services at Kingsgrove.
Postby molybtek » Wed Dec 13, 2017 9:24 am
Hopefully the changes to the T8 trains will also include Glenfield-Macarthur section as well because during the peak, there are gaps of about 20 minutes between trains, and the train for Macarthur departs a few minutes before the T5 train arrives at Glenfield.
molybtek
Has thanked: 6 times
Been thanked: 24 times
Postby Liamena » Wed Dec 13, 2017 4:26 pm
Doesn't the 400 go past Kingsgrove on the way to Campsie ?
Liamena
Postby Fleet Lists » Wed Dec 13, 2017 4:44 pm
Postby quaidy » Wed Dec 13, 2017 5:38 pm
Stu wrote:T8 timetable modification if most probably due to the poor connection time between limited stops services and all stops services. I would suspect that another singular station will be added to the limited stops services between the City and Macarthur to aid better connections beteeen services. It is sheer arrogance to allow the all stations service to depart Revesby 3 minutes before the city bound service from Macrthur arrives into Revesby and then expect customers to happily wait 12 minutes for the next all stations service to depart Revesby. The weekend provides 0 minutes of connection time, although there is a 30-60 second window of opportunity it will only be successful if both trains are on the same island platform (1 & 2), good luck trying to whip quickly up one stair case and down another stair case if the all stations services is on the other platform island (3 & 4) - depends on how fit you are and what carriage that you on in the Macarthur train as toubalight from it.
It would be almost impossible to keep everybody happy with connections. The best thing is to increase frequency to at least every 15 minutes, so that worst-case wait times are minimized. I can’t imagine there would be huge volumes of people traveling from Campbelltown and getting off at stations between Revesby and Wolli Creek .
quaidy
Has thanked: 19 times
Been thanked: 19 times
Postby aman » Wed Dec 13, 2017 7:04 pm
I honestly don't think they'll add Padstow and Riverwood back into the stopping patterns, it greatly reduces operational flexibility by forcing the trains to use the local tracks. They would have known when they did the timetable that the connections weren't possible, I'm pretty sure they correlated the data and realised that not many people do the transfer at Revesby (compared to pure city bound passengers). You can't please everyone but I can't see them adding those stops back.
Spending all that money for 10 trains a day either way is a waste of money.
They do provide an interchange at Padstow and Riverwood during peak, I'm guessing the data is saying that's when the large majority of transfers occur. (I think a few go All to Holsworthy - Padstow - Riverwood - Wolli Creek) and the interchange time is quite reasonable. (around 3 mins wait looking at the TT)
aman
Been thanked: 3 times
Postby Frosty » Wed Dec 13, 2017 7:41 pm
Maybe they could be modifying the weekend timetable as between Wolli Creek & City its a weird 4-11 minute frequency. Since it kind of creates uneven loadings on the trains through the Airport stations also does rely on all stops train to run on time as to not hold up the limited stops train between Wolli & the City.
They could also maybe add an extra 30 seconds in dwell times at Green Square & Mascot to ensure on-time running since patronage is going to grow even further. Unless they start running express buses parallel to the railway line.
Postby Stu » Wed Dec 13, 2017 9:46 pm
I have to admit that I do enjoy the boost in frequency although I do miss the previous better standard of connections between the limited stops service and the all stations service. Maybe an all stations service that would normally commence from Revesby could be modified to depart platform 1 at East Hills and slotted in between the respective limited stops services from Macarthur.
Postby aman » Wed Dec 13, 2017 9:55 pm
Frosty wrote:Maybe they could be modifying the weekend timetable as between Wolli Creek & City its a weird 4-11 minute frequency. Since it kind of creates uneven loadings on the trains through the Airport stations also does rely on all stops train to run on time as to not hold up the limited stops train between Wolli & the City.
Yeah sure, adding dwell times is the solution. Sooner it would be quicker to walk. I propose adding 10 minutes dwell time to all stations, then they can't possibly be late, until the next Monday occurs.
aman
Postby Liamena » Thu Dec 14, 2017 5:49 am
It does seem rather pointless that they built the 4 tracks and don't use them. But I only go there on weekends.
Liamena
Users browsing this forum: Google [Bot] and 9 guests
