Use of Back Door on Buses
Re: Use of Back Door on Buses
Postby simonl » Sun Nov 26, 2017 12:29 pm
booma wrote:There is supposed to be all door loading at Carrington st Wynyard from nov 26th.
Stands A B C & D.
Supervised PM rear door loading or generalised rear door loading?
Has thanked: 848 times
Been thanked: 364 times
Postby Swift » Sun Nov 26, 2017 3:20 pm
simonl wrote:Supervised PM rear door loading or generalised rear door loading?
Take a stab in the dark!
2582 in George Street Haymarket 2005.
Has thanked: 568 times
Been thanked: 457 times
Postby simonl » Sun Nov 26, 2017 4:22 pm
^ I'd have thought supervised PM peak rear door loading would already be in place!
Postby Swift » Sun Nov 26, 2017 4:25 pm
simonl wrote:^ I'd have thought supervised PM peak rear door loading would already be in place!
They trialled it in other locations but not there, where it was sorely needed. Glad to see them trying something different there finally. 36 years is a long time.
Postby Qantas94Heavy » Tue Nov 28, 2017 8:35 pm
Got on a bus at Carrington Street Stand A during PM peak today. All door boarding was in effect but dwell time still wasn't great -- 1:35 to load roughly 60-62 people onto a bus.
Most people were using the rear door, with only a few people using the front door after marshals asked them to.
Qantas94Heavy
Been thanked: 9 times
Postby Swift » Tue Nov 28, 2017 8:46 pm
The idea is distribution, not to switch doors! Public!!
Postby tonyp » Wed Nov 29, 2017 5:31 am
Qantas94Heavy wrote:Got on a bus at Carrington Street Stand A during PM peak today. All door boarding was in effect but dwell time still wasn't great -- 1:35 to load roughly 60-62 people onto a bus.
They're biasing towards the centre door because that has best and quickest access to the bulk of the passenger space (and seats). The general pattern you will observe in Europe is that most will use centre and rear doors for passenger exchange and the front door is pretty quiet.
Here's another example of other-door bias in this "ATDB training video" from our Mr OCB! This is exchange of about 40 people (on and off) in 40 seconds.
https://www.youtube.com/watch?v=j-3ydX_GIkY
In spite of the centre-door bias though, this is infinitely better at, not only boarding them, but distributing the load through the bus and avoiding the choking-up of the front half of the bus and thus its incomplete loading that you get with front-door loading.
With high-turnover work or with crowds like 60 or so exchanging all at once, the need for more doors also kicks in and you need a vehicle like this:
Optare 3 door.jpg (250.6 KiB) Viewed 4872 times
or even better, this:
Has thanked: 824 times
Been thanked: 946 times
Postby Glen » Fri Dec 08, 2017 3:38 pm
Meanwhile in another state, far far away:
https://www.adelaidemetro.com.au/Announ ... Bahn-buses
Been thanked: 185 times
Postby tonyp » Fri Dec 08, 2017 3:57 pm
Glen wrote:Meanwhile in another state, far far away:
Postby Swift » Fri Dec 08, 2017 5:41 pm
I don't think a squashed up drive train like that would cope well with Sydney's combination of hilly terrain and hotter weather.
Adelaide has always been ahead of the game compared to Sydney with the operation of their buses. It helps that it it's a much more compact provincial city that is more manageable with a political climate far more amenable to new ideas.
Adelaide has had to be innovative as their bus system has been their mainstay of public transport for decades.
Just compare their extra wide underfloor buses from the 1950s to Sydney's versions.
Postby tonyp » Sat Dec 09, 2017 9:19 am
If you look at the roof of that bus, you will see that the drive-train is most definitely not squashed up!
But even if it was fuel-engined, as you know for example riding the B Line, compact vertical rear engines are common nowadays. ;)
Postby Swift » Wed Dec 13, 2017 10:55 pm
Here is a stop gap for better egress.
Postby tonyp » Wed Dec 13, 2017 11:01 pm
Already available - at least in LHD.
Postby Swift » Wed Dec 13, 2017 11:04 pm
I only applied colour and a decal + flipped the image. I did not add or remove any doors.
Postby tonyp » Tue Jan 30, 2018 7:50 am
After a little more reflection on particular cases over time, I've reached the conclusion that there needs to be a more sophisticated formula for calculating capacity in a train, tram or bus. Per meterage on floor area (taking into account axle load of course) is good in theory but it has to be modified for reality according to the number and distribution of doors (and whether all those doors are used for both loading and exit or not). You can jam 100 people on an Australian 12 metre bus or 1,700 on a Sydney double deck train for example if everybody is just being transported from A to B (e.g. a sporting event) and nobody wants to get on and off along the way. As soon as you get passenger turnover, the reality changes dramatically according to the numbers vs the door situation - unless operators are prepared to tolerate stop dwells that stretch to infinity.
As these vehicles in Europe demonstrate with their significantly higher capacity, a train with a flat floor and 3 or 4 doors per car is going to have a higher practical capacity than an equivalent-length one with 2 doors and a double deck; a tram with 2 doors per module is going to do better than one with one door per module; a 12 metre bus with 3 to 4 doors is going to be better on practical capacity than one with 2 doors (let alone 1 door!) and so on. It seems to me that there needs to be some sort of passengers-per-door per rate of turnover (passenger exchange) calculation factored in as well as the traditional floor area/seating calculation.
Postby Swift » Tue Jan 30, 2018 2:03 pm
They need to put in a fifth door on the off side for the driver to access his hermetically sealed compartment with sound proofing so they don't have to hear abuse and silly unnecessary queries from passengers. Make it two way mirror screen so passengers can't see the driver either!!
Postby matthewg » Thu Feb 01, 2018 6:12 am
Swift wrote:They need to put in a fifth door on the off side for the driver to access his hermetically sealed compartment with sound proofing so they don't have to hear abuse and silly unnecessary queries from passengers. Make it two way mirror screen so passengers can't see the driver either!!
That would make it easy to introduce full automation, as the passengers no longer being able to see the driver up front, won't know if the human has been replaced by a machine or not :-)
Has thanked: 86 times
Been thanked: 264 times
Postby moa999 » Wed Feb 14, 2018 9:31 am
Saw a driver go absolutely mental at an Asian pax with seemingly limited English (possibly tourist) who dived in the centre door of an M20 artic.
One thing I noted is that if the doors are open - there is absolutely nothing on the side of the doors, or steps etc to say No Entry.
The only visible no entry sticker is on the outside of the doors which is only visible when closed, when you open the doors it's hidden.
It's time to ditch this archaic practice at all stops.
Has thanked: 288 times
Been thanked: 286 times
Postby Nugget » Wed Feb 14, 2018 10:42 am
moa999 wrote:Saw a driver go absolutely mental at an Asian pax with seemingly limited English (possibly tourist) who dived in the centre door of an M20 artic.
Also there was a time when the Metrobus was all door boarding with prepay only etc. Given there is now Opal, prepay only and readers at every door there is no possible sane reason why all door boarding should not be allowed.
Nugget
Been thanked: 7 times
Postby Swift » Wed Feb 14, 2018 3:11 pm
Safe -tee according to the union. Forget fool proof interlocks, making it impossible to drag a passenger off down the road by their leg, and cameras pointed to the doors. The wing mirror also. honestly, Sydney's developing culture of over caution is suffocating.
Postby simonl » Wed Feb 14, 2018 8:15 pm
Nugget wrote:Also there was a time when the Metrobus was all door boarding with prepay only etc.
I'm sure that part is incorrect. Only the 891 had such an arrangement.
Postby tonyp » Wed Feb 14, 2018 9:36 pm
I would have thought that no STA service would ever have had unsupervised (that is, without attendants on the footpath) all-door loading.
Admin: the word “attendants” substituted
Postby molybtek » Fri Feb 23, 2018 8:00 am
I've used public transport for the first time after the timetable change - was surprised how busy Parramatta bus interchange was in the evening peak. They even had a bus marshal there who asked the bus driver to open the back door for boarding.
The service I got on was a T64, is the use of back door boarding at Parramatta a regular occurrence now?
molybtek
Has thanked: 6 times
Been thanked: 24 times
Postby Tonymercury » Fri Feb 23, 2018 8:59 am
tonyp wrote:I would have thought that no STA service would ever have had unsupervised (that is, without attendants on the footpath) all-door loading.
I had an 'uneducated' operator do it at Mascot shops yesterday
Has thanked: 260 times
Been thanked: 335 times
Postby tonyp » Sun Apr 15, 2018 1:44 pm
1. Sydney STA bus deals with huge railway crowd:
https://www.youtube.com/watch?v=foSHdU7ZqF8
2. Toronto bus deals with huge railway crowd:
https://www.youtube.com/watch?v=yPtwbpByPds
1. Could be a still-life painting, crowd doesn't move, just one door that keeps opening and shutting then stays shut after a handfull board, plenty of room inside.
2. Likewise not the best sort of vehicle for the job capacity-wise, but at least everything is moving and filling through every available opening.
Users browsing this forum: No registered users and 7 guests
