The root cause, as I'm sure you know already, is likely a failed GPS on the bus, in conjunction with a driver that wasn't attentive enough to manually advance the system from stop to stop.
boronia wrote:The bus starts from Little Bay about 0600, so I doubt driver change could be blamed.
moa999 wrote:The root cause, as I'm sure you know already, is likely a failed GPS on the bus, in conjunction with a driver that wasn't attentive enough to manually advance the system from stop to stop.
Albeit in most cases this would result in a reversal (as the tag off location is same as tag on).
In this case the GPS has seemingly not worked from route commencement at Little Bay to Kensington, before switching on before Central
Only other thing I can think of is a driver change nearby whereby power was incorrectly shutoff so the system defaulted to start of route (as the driver logged in) before it established GPS. (Had this occur to me in the early days boarding at Edgecliff and being charged from Watson's Bay)
Frosty wrote:boronia wrote:The bus starts from Little Bay about 0600, so I doubt driver change could be blamed.
Could be a problem when the driver finished another route and then headed to Little Bay since I know a few 309/391s run empty becoming 393s at Little Bay. Drivers probably also like to take a break at P depot and shutoff in between empty runs/breaks if they're near Port Botany Depot which is near Little Bay. Maybe driver failed to shut down properly after going the depot for a quick snack or toilet break in between runs nearby P depot.
Fleet Lists wrote:I have never heard of any threat to deactivate card because of multiple no tap offs - i suspect that you heard some false rumour. Why would they deactivate them when they are making money out of trips which are not tapped off?
jpp42 wrote:The Opal Travel app is telling me I've reached the weekly travel reward despite it clearly being Monday and only three journeys so far today. Anyone else seeing this?
Fleet Lists wrote:But whose fault is that? I dont believe it is a case of overcharging under such circumstances.
3808 wrote:PGT - one possible explanation for your July experience is that once the day-cap is reached on a Sunday, the system doesn't bother doing the other adjustments. It would be interesting to see what would happen if someone did the same journey sequence on a weekday.
Users browsing this forum: Baidu [Spider] and 6 guests
