*Opal Card INFRASTRUCTURE roll-out progress ONLY*
Re: *Opal Card INFRASTRUCTURE roll-out progress ONLY*
Postby Fleet Lists » Tue Jul 12, 2016 3:28 pm
I think the previous post shows the wrong links as it links to locations with top up mchines which shows only 93 locations
Link should be https://www.opal.com.au/en/get-an-opal- ... p-tickets/
Has thanked: 941 times
Been thanked: 998 times
Postby Mike M » Tue Jul 12, 2016 5:51 pm
Pardon my ignorance but can anyone explain why some stations only have machines which accept credit cards while others have machines which accept both cash & credit cards? Is there any logic to this because looking at the two lists of locations on the Opal website I can't see any.
Just for the record all Myki machines here in Melbourne accept cash & cards.
Mike M
Has thanked: 9 times
Been thanked: 54 times
Postby simonl » Tue Jul 12, 2016 6:17 pm
And in Qld too - every railway station up to Gympie has a cash/card top up which also allows balance/history enquiry.
Some others also dispense go cards.
Has thanked: 834 times
Been thanked: 357 times
Postby crimsontide » Wed Jul 13, 2016 4:46 pm
Mike M wrote:Pardon my ignorance but can anyone explain why some stations only have machines which accept credit cards while others have machines which accept both cash & credit cards? Is there any logic to this because looking at the two lists of locations on the Opal website I can't see any.
A combination of Station patronage, and nearby Opal retailers seems to be a rough criteria in deciding who gets what.
crimsontide
Has thanked: 218 times
Been thanked: 113 times
Postby boxythingy » Thu Jul 28, 2016 2:25 am
New readers up at Central LR Stop, most people still stick with the original readers rather than use the new ones and quickly walk into Central(i)
Australia brags about its political system, but their PM says one thing during the election; something else when (s)he takes office, something else at midterm and something else when (s)he leaves.
boxythingy
Has thanked: 1746 times
Been thanked: 265 times
Postby matthewg » Thu Jul 28, 2016 10:07 am
The card only machines are probably much cheaper. No note/coin acceptors, no change mechanisms and no need of a 'cash safe'. The machine just needs to be kept supplied with low-value consumables, so the ongoing maintenance would only require normal delivery contractors instead of Chubb armoured delivery contractors.
So there will be an incentive to put as many card-only machines in as possible.
My station has card only Opal next to a full cash/card accepting mag ticket machine. It's possible on the stage 2 rollout, this machine will get replaced with a cash+card Opal machine. (It's also possible, and more likely I expect, they will just rip the machine out and pave over the hole left behind).
Has thanked: 85 times
Been thanked: 247 times
Postby sunnyyan » Thu Jul 28, 2016 4:08 pm
Campsie has a full size mag ticket machine and 2 card only Opal machines, one being able to dispense single trips. There used to be another mag ticket machine, but they removed it and covered the hole with a sheet of metal that isn't even fastened on.
sunnyyan
Has thanked: 26 times
Been thanked: 22 times
Favourite Vehicle: MB OC500LE CC CB60 Evo I CNG
Postby MLVD » Sat Jul 30, 2016 4:06 am
Top up machine installed at Toongabbie yesterday in the middle of platform 1/2.
MLVD
Been thanked: 5 times
Postby moa999 » Mon Aug 01, 2016 2:08 am
Fleet Lists wrote:I think the previous post shows the wrong links as it links to locations with top up mchines which shows only 93 locations
Link has changed completely throwing out my Update Scanner plugin - current count is now:
182 cash and card (+2) and 65 card only (--) -- Total 247 (+2)
Toongabbie would appear to be one of the additions, Central (Light Rail) might be the other
New link is now:
https://www.opal.com.au/en/get-an-opal- ... e-tickets/
Has thanked: 244 times
Re: Introducing OPAL Card
Postby moa999 » Wed Aug 03, 2016 12:46 am
Caught a couple of W buses tonight with green machines removed and replaced with a light grey coverplate
(silly choice of colour, should be much darker to match) but good to see they are getting rid of machines pronto
Postby Jurassic_Joke » Wed Aug 03, 2016 1:46 am
actually, one bus i caught today, the green machines were still intact and turned on (judging by the green hand-symbol), I wonder what would happen if you then tried dipping in a travel 10, ignoring the fact the driver usually doesnt care about whether or not people use a valid ticket
:D
Has thanked: 34 times
Been thanked: 52 times
Favourite Vehicle: Volvo B12BLEA articulated
Postby eBlog42 » Wed Aug 03, 2016 11:05 am
moa999 wrote:Caught a couple of W buses tonight with green machines removed and replaced with a light grey coverplate
It's a slow process to remove those green machines Image
eBlog42
Has thanked: 3 times
Been thanked: 31 times
Postby moa999 » Wed Aug 03, 2016 4:23 pm
That's them. Having caught a few more buses today it matches well on the Custom builds, just the newer Bustechs where the colour stands out, due to their greater use of dark plastics
Postby Mark » Wed Aug 03, 2016 10:40 pm
I wonder why the STA went to the trouble & expense of installing these panels to cover the mounting brackets. I would've thought it would make more sense to remove the mounting brackets while removing the green machines. It's not like the brackets are going to be used for anything ever again. And particularly on the VSTs, it frees up room in the storage area on the near side.
Mark
Been thanked: 4 times
Favourite Vehicle: Mercedes Benz O305
Postby matthewg » Thu Aug 04, 2016 3:40 am
Mark wrote:I wonder why the STA went to the trouble & expense of installing these panels to cover the mounting brackets. I would've thought it would make more sense to remove the mounting brackets while removing the green machines. It's not like the brackets are going to be used for anything ever again. And particularly on the VSTs, it frees up room in the storage area on the near side.
The machines can be pulled out quickly (they repair by swap). Removing the brackets and associated wiring would take some time. Much quicker just to put a cover over the bracket and pretend it isn't there anymore.
Postby Geo101 » Fri Aug 05, 2016 8:05 pm
Possibly a public liability issue? Do the brackets have sharp edges perhaps.
Geo101
Has thanked: 5 times
Postby boronia » Fri Aug 05, 2016 9:45 pm
They have been running many of the newer VSTs without machines, but with the brackets exposed, for some months now.
These covers look much neater
On again May 2018
Has thanked: 250 times
Been thanked: 1523 times
Postby crimsontide » Tue Aug 09, 2016 2:52 pm
mandonov wrote:After August 1 I suspect the removal of paper ticket machines will be quite swift.
Not so Swift, plenty of places still have them a Week later.
crimsontide
Postby Jurassic_Joke » Tue Aug 09, 2016 5:55 pm
You know what, I'm going to haphazard a guess and say that perhaps, on these white covers at the front of the bus, they'll cover them with a plastic sticker showing the Opal Single Trip ticket prices.
Thats the only thing I can imagine why theres something put there in place of the green machines. But otherwise, yes, I agree with other posters, the covers are camouflaged very well on the Custom Coaches 0405NH / CNG buses, but on other types they stand out a bit more.
:D
Postby Stu » Tue Aug 09, 2016 9:41 pm
The entire mounting for the tr2 on the Bustech bodies should have been removed altogether. There is a small horizontal bar that extends away from the main support arch, this small pole should have been cut off and then the side of the arch could have been sealed very discreetly. Instead, what remains is a dormant piece of metal sitting in the luggage rack area thus continuing to make it very difficult for people to successfully load large luggage bags into the luggage rack which is what that area is intended for. The tr machine should never have been located on this side of the arch in the first place.
Has thanked: 100 times
Been thanked: 389 times
Postby moa999 » Fri Aug 12, 2016 3:19 pm
Noticed all three old ticket machines removed at Kings Cross this afternoon and sitting near the escalators.
Assume this will be repeated at most stations
Postby boronia » Fri Aug 12, 2016 3:49 pm
They would want to remove the TRs as quickly as possible. to discourage people from attempting to use them. As removal of the bases and wiring would take some time, the covers seem to be a good safety measure.
They probably want to discourage people from buying "opal" tickets on board buses, so not advertising they are available might be the way to help.
On again May 2018
Postby matthewg » Thu Aug 18, 2016 8:12 pm
I noticed this afternoon that the last of the mag ticket readers have been removed from the barriers at Redfern. Including the platform 10 barriers which now display 'Opal cards only', yet don't have Opal readers. or magnetic readers now. Sitting there with no actual ticket readers at all. Not sure why the bothered to rip the mag ticket readers out and update them to read 'Opal Only' when the barriers are completely inoperable now. Might as well have pulled em out.
Postby matthewg » Fri Aug 19, 2016 9:20 am
The country's (world's ?) most useless fare gate.
Snapped a picture on the way though this morning.
Redfern Platform 10 fare gates.
Postby rogf24 » Fri Aug 19, 2016 9:09 pm
County? Could that be Cumberland County?
rogf24
Has thanked: 60 times
Been thanked: 100 times
Users browsing this forum: tonyp and 13 guests
