While trying to bleed my system of air I put Diesel in the pump where it should havexxxxxxx???. I have looked online for some sort of manual for pump without luck I do have the Atlantean manual but is only has limited information about pump . I have read the manual and bleed out the air but it still will not pump fuel out of the top when I disconnect the injector line from top of pump so engine will not start.
Update: Plate on inline injection pump: CAV DES Type N then stamped in centre top of body of pump 1097
There is a large plate in the centre of the pump held by the bolts
There is a filler plug as well , behind this is the springs for the injectors
What is the purpose of the filler plug? Is it filled with fuel?
When I pump the lift pump fuel comes out the bottom where the springs are?
C.A.V. Injection Pump 680 Leyland Atlantean Double Decker
- Attachments
- injection pump 003.JPG (73.66 KiB) Viewed 4734 times
- Guy_Arab
- Favourite Vehicle: M.A.N Bus & Guy Arab
Re: C.A.V. Injection Pump 680 Leyland Atlantean Double Decke
I can ,look up the Leyland manual for you let me know I am overseas at moment will not be back till 29th October but will see if I have a copy on file with mealex117 wrote:While trying to bleed my system of air I put Diesel in the pump where it should have oil. I want to drain this and fill with proper oil. What oil is used to fill the C.A.V. Type N injection pump. Also I have looked online for some sort of manual for pump without luck I do have the Atlantean manual but is only has limited information about pump . I have read the manual and bleed out the air but it still will not pump fuel out of the top when I disconnect the injector line from top of pump so engine will not start.
GUY ARAB
yes let me know I have 3 different manuals but not the one for the Australia 1970 Atlantean alexgoodhart@ymail.com
- Guy_Arab
ON MY RETURNalex117 wrote:yes let me know I have 3 different manuals but not the one for the Australia 1970 Atlantean alexgoodhart@ymail.com
my manual is the UK SERVICE AND REPAIR I still overseas but try and help
GUY ARAB
